Giriş
The tripod port may be loose, broken or faulty. In any case, replacement of the tripod port involves first removing the LCD Screen and the Motherboard. Please refer to the LCD Screen prerequisite guide and the Motherboard prerequisite guide for proper removal of the LCD Screen and the Motherboard.
Neye ihtiyacın var
Using a screwdriver, remove the five 6mm screws located on the back panel.
Using a screwdriver, remove the two 3mm screws located on the back panel.
Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
Using a screwdriver, remove the four 4mm screws from the motherboard.
Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
