Ana içeriğe geç
Sony Cyber-shot DSC-H300 Batteries Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H300 Batteries Replacement, Batteries: adım 1, 1 resimden 1.
    • Flip the camera over to look at the bottom side.
  2. Sony Cyber-shot DSC-H300 Batteries Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-H300 Batteries Replacement: adım 2, 2 resimden 2.
    • Place thumb on battery cover and slide outward until it springs open.
  3. Sony Cyber-shot DSC-H300 Batteries Replacement: adım 3, 1 resimden 1.
    • Remove the batteries.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zachary Meyer
479 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Nance Spring 2018 USF Tampa, Team S1-G6, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G6
3 Üyeler
10 adet Kılavuz yazıldı
7 Yorum
I got the Sony Cyber-shot DSC-H300. I didn't see any battery charge pack in it, only the batteries.
Please I want to know if I'm required to charge the batteries or only replace them when they discharge
Nee Nath - Yanıt
This uses AA batteries. I’m sure you could use rechargeable batteries as well but I just replace them
Terri S. -
My battery door won't open. It was working until now. Any suggestions?
jer2911alexis - Yanıt
For any one with this issue it might mean you batteries might have leaked and you can check if there is any white colored residue at the unlock button if , as with my camera i saw some residue, after using something that will not leave marks to push it to unlock position and try to force it a bit to the side the cover, just enough to push something in the edge of cover and housing on the underside near edge of battery cover hinge , to push out the cover a bit more to the side so it slides out to open it and then lift up , just have to clean out the residue of leaked battery of everything in special metal battery contacts on the battery cover , i am trying to find out if there are any replacement parts to replace the metal battery contacts, as i haven`t seen anything yet here
shydar -
The camera door will no longer spring ooen. Any suggestions?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 58
Son 30 gün: 178
Her zaman: 10,972
