Ana içeriğe geç
Sony Cyber-shot DSC-H300 Flash Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: adım 1, 2 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: adım 1, 2 resimden 2.
    • Remove the four 6mm Phillips #00 screws.
  2. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: adım 2, 2 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: adım 2, 2 resimden 2.
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
  3. Sony Cyber-shot DSC-H300 Flash Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-H300 Flash Replacement: adım 3, 3 resimden 3.
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
  4. Sony Cyber-shot DSC-H300 Flash Replacement, Flash: adım 4, 3 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement, Flash: adım 4, 3 resimden 2. Sony Cyber-shot DSC-H300 Flash Replacement, Flash: adım 4, 3 resimden 3.
    • Remove the six 6mm Phillips #00 screws from the upper case of the camera.
    • Remove the upper case.
  5. Sony Cyber-shot DSC-H300 Flash Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement: adım 5, 2 resimden 2.
    • Remove the four 6mm Phillips #000 screws from the bottom of the case.
  6. Sony Cyber-shot DSC-H300 Flash Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-H300 Flash Replacement: adım 6, 2 resimden 2.
    • Slide the flash out and away from the camera to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nassr Al Mandhari
121 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Nance Spring 2018 USF Tampa, Team S1-G6, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 1,951
