Ana içeriğe geç
Sony Cyber-shot DSC-H300 Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: adım 1, 2 resimden 1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: adım 1, 2 resimden 2.
    • Remove the four 6mm Phillips #00 screws.
  2. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: adım 2, 2 resimden 1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: adım 2, 2 resimden 2.
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
    you need to remove one more screw inside the battery cover, you will see it once you open the battery cover.
    Belzebuth - Yanıt
  3. Sony Cyber-shot DSC-H300 Screen Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-H300 Screen Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-H300 Screen Replacement: adım 3, 3 resimden 3.
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
  4. Sony Cyber-shot DSC-H300 Screen Replacement, Screen: adım 4, 1 resimden 1.
    • Remove the two 6 mm Phillips #00 screws securing the left side of the metal frame.
    • Gently pull the metal frame away from the screen.
    • Lift the screen with the spudger and flip it to the right.
  5. Sony Cyber-shot DSC-H300 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the four 6mm Phillips #00 black screws.
    • Lift the metal plate away from the board.
  6. Sony Cyber-shot DSC-H300 Screen Replacement: adım 6, 1 resimden 1.
    • Disconnect the LCD cable.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zachary Meyer
479 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Nance Spring 2018 USF Tampa, Team S1-G6, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G6
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
where can i find the rear screen for sony dsc-h300
Michael Ramos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 66
Her zaman: 2,208
