Ana içeriğe geç
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Brianna Greenlaw
1.217 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G3
4 Üyeler
10 adet Kılavuz yazıldı
5 Yorum
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Yanıt
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Yanıt
Display my order
prince Choudhary - Yanıt
Screen LCDOnline booking
qual tela de lcd posso usar?
não achei
Thayane Laurencio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 3,510
