Ana içeriğe geç
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: adım 1, 1 resimden 1.
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 2, 3 resimden 3.
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 3, 1 resimden 1.
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 4, 1 resimden 1.
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 5, 1 resimden 1.
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: adım 6, 3 resimden 3.
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Sonuç
Bir başkası bu kılavuzu tamamladı.
DaQuawn
254 İtibar
2 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 996
