Ana içeriğe geç
Sony Cyber-shot DSC-HX300 View Finder Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-HX300 View Finder Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 2, 1 resimden 1.
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 3, 1 resimden 1.
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 4, 2 resimden 2.
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: adım 5, 3 resimden 1. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: adım 5, 3 resimden 2. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: adım 5, 3 resimden 3.
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
  6. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 7, 1 resimden 1.
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 8, 2 resimden 2.
    • Remove the 1 (2 cm) Phillips head screw
    • Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
    • Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
  9. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 9, 2 resimden 1. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 9, 2 resimden 2.
    • Gently pull the plastic View Finder off of the metal mounting bracket.
  10. Sony Cyber-shot DSC-HX300 View Finder Replacement: adım 10, 1 resimden 1.
    • The replacement View Finder can now be installed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth Surface
1.465 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G6
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 27
Her zaman: 1,303
