Giriş
In the event of a damaged LCD screen, the only option may be for you to replace it. The following guide will take you step by step through the process.
Neye ihtiyacın var
Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
4 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
where can i find the screen other then threw sony
