Ana içeriğe geç
Sony Cyber-shot DSC-HX80 LCD Screen Replacement
Gordon Jones
Gordon Jones ve 4 diğer katkıda bulunanlar
En son September 28, 2024 tarihinde güncellendi
25 dakika
Zor
In the event of a damaged LCD screen, the only option may be for you to replace it. The following guide will take you step by step through the process.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gordon Jones
1.081 İtibar
5 adet Kılavuz yazıldı
Ekip
7 Yorum
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - Yanıt
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - Yanıt
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
Facundo V -
where can i find the screen other then threw sony
ninjadawn25 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 49
Her zaman: 3,908
