Ana içeriğe geç
Sony Cyber-shot DSC-HX90V Button Board Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: adım 1, 3 resimden 1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: adım 1, 3 resimden 2. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: adım 1, 3 resimden 3.
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 2, 3 resimden 3.
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Sonuç
Marin Rusinov
853 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 2,300
