Ana içeriğe geç
Sony Cyber-shot DSC-P100 Camera Flash Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: adım 1, 3 resimden 1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: adım 1, 3 resimden 2. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: adım 1, 3 resimden 3.
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 2, 1 resimden 1.
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 3, 1 resimden 1.
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 4, 2 resimden 2.
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: adım 5, 2 resimden 1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: adım 6, 3 resimden 3.
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Sonuç
Katie McCraw
191 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 üyesi
CLEM-BENSON-S12S1G5
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 2,718
