Ana içeriğe geç
Sony Cyber-shot DSC-P52 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: adım 1, 1 resimden 1.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: adım 2, 1 resimden 1.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: adım 3, 1 resimden 1.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: adım 4, 1 resimden 1.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: adım 5, 1 resimden 1.
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: adım 6, 1 resimden 1.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: adım 7, 1 resimden 1.
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: adım 8, 1 resimden 1.
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: adım 9, 1 resimden 1.
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: adım 10, 1 resimden 1.
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: adım 11, 1 resimden 1.
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: adım 12, 1 resimden 1.
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: adım 13, 1 resimden 1.
    • Repeat steps in reverse order to reassemble the camera
Sonuç
Mark
13 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G43
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 2,490
