Ana içeriğe geç
Sony Cyber-shot DSC-P9 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: adım 2, 1 resimden 1.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-P9 LCD Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: adım 4, 1 resimden 1.
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-P9 LCD Replacement: adım 5, 2 resimden 2.
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: adım 6, 1 resimden 1.
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: adım 7, 2 resimden 1. Sony Cyber-shot DSC-P9 LCD Replacement: adım 7, 2 resimden 2.
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: adım 8, 1 resimden 1.
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: adım 9, 1 resimden 1.
    • The LCD is now separated from the camera.
Sonuç
Jenna Crawford
50 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G25
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 965
