Ana içeriğe geç
Sony Cyber-shot DSC-P9 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 2, 1 resimden 1.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: adım 4, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: adım 4, 2 resimden 2.
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 5, 2 resimden 2.
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 6, 2 resimden 2.
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 7, 1 resimden 1.
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: adım 8, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: adım 8, 2 resimden 2.
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 9, 1 resimden 1.
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 10, 1 resimden 1.
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 12, 3 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 12, 3 resimden 2. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 12, 3 resimden 3.
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 13, 1 resimden 1.
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 14, 1 resimden 1.
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 15, 3 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 15, 3 resimden 2. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 15, 3 resimden 3.
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
  16. Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: adım 16, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: adım 16, 2 resimden 2.
    • Rotate the bottom panel upwards and pull away with your hand.
  17. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the one 2.5mm Phillips #000 screw on the bottom corner of the motherboard.
  18. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 18, 1 resimden 1.
    • Lift the black tab holding the top-left ribbon cable in place with the spudger tool.
    • Remove the ribbon cable with the spudger by carefully pulling the cable directly out of the slot.
    • Take care not to rip the ribbon cable when pulling it out.
  19. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 19, 1 resimden 1.
    • Lift the black tab that locks the orange ribbon cable in place.
    • Remove the ribbon cable by gently pulling it out of the slot with the spudger.
    • Take care not to rip the ribbon cable when pulling it out, and be mindful of a second cable beneath the first.
  20. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 20, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 20, 2 resimden 2.
    • Remove the second ribbon cable below the first one by gently pulling it out of the slot with the spudger.
  21. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 21, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 21, 2 resimden 2.
    • Remove the ribbon cable to the right of the bottom two ribbon cables with the spudger.
  22. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 22, 2 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 22, 2 resimden 2.
    • Pull the motherboard out of the slot on the side of the camera where the lens used to be attached.
  23. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 23, 3 resimden 1. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 23, 3 resimden 2. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 23, 3 resimden 3.
    • Lift the motherboard away from the camera.
    • Detach the final ribbon cable connecting the motherboard to the rest of the camera.
  24. Sony Cyber-shot DSC-P9 Motherboard Replacement: adım 24, 1 resimden 1.
    • The motherboard should now be fully disconnected from the rest of the camera.
Sonuç
Robert Potter
41 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G25
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 1,305
