Ana içeriğe geç
Sony Cyber-shot DSC-P9 Outer Casing Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 2, 1 resimden 1.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: adım 4, 2 resimden 1. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: adım 4, 2 resimden 2.
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 5, 2 resimden 2.
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 6, 2 resimden 2.
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Outer Casing Replacement: adım 7, 1 resimden 1.
    • After the casing is removed, the camera should look as shown.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jenna Crawford
50 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G25
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 823
