Ana içeriğe geç
Sony Cyber-shot DSC-S2100 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: adım 1, 3 resimden 1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: adım 1, 3 resimden 2. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 2, 3 resimden 3.
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 3, 3 resimden 3.
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 4, 3 resimden 3.
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: adım 5, 1 resimden 1.
    • Ensure the screen displayed greets you, once you reassembled your camera
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
oldturkey03
813.187 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
702 adet Kılavuz yazıldı
2 Yorum
你在哪里?把相机给你帮我挨可以吗
Jeanne - Yanıt
请问你是在多伦多附近吗?
Jeanne - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 81
Her zaman: 3,040
