Ana içeriğe geç
Sony Cyber-shot DSC-T1 LCD screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 2, 1 resimden 1.
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: adım 3, 3 resimden 1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: adım 3, 3 resimden 2. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: adım 3, 3 resimden 3.
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 4, 1 resimden 1.
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 5, 1 resimden 1.
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 6, 1 resimden 1.
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 7, 2 resimden 1. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 8, 2 resimden 2.
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
  9. Sony Cyber-shot DSC-T1 LCD screen Replacement, LCD screen: adım 9, 1 resimden 1.
    • Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
  10. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 10, 2 resimden 2.
    • Flip the motherboard unit up to expose the metal plate beneath it.
    • Remove the four 3mm screws shown using the 00 screwdriver.
  11. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 11, 1 resimden 1.
    • Lift and remove the metal plate covering the LCD screen from the camera.
  12. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 12, 3 resimden 1. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 12, 3 resimden 2. Sony Cyber-shot DSC-T1 LCD screen Replacement: adım 12, 3 resimden 3.
    • Flip the LCD over to the other side of the camera.
    • Peel the tape connecting the LCD to the camera.
    • Remove LCD screen
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Paul Elrich
45 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G35
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 3,810
