Ana içeriğe geç
Sony Cyber-shot DSC-T9 AV Port Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: adım 1, 1 resimden 1.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 2, 1 resimden 1.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: adım 3, 1 resimden 1.
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 4, 1 resimden 1.
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 5, 3 resimden 1. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 5, 3 resimden 2. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 5, 3 resimden 3.
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 6, 3 resimden 3.
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 7, 1 resimden 1.
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 8, 1 resimden 1.
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: adım 9, 1 resimden 1.
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 10, 1 resimden 1.
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 11, 1 resimden 1.
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 12, 1 resimden 1.
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: adım 13, 2 resimden 1. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: adım 13, 2 resimden 2.
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 14, 1 resimden 1.
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 15, 1 resimden 1.
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: adım 16, 1 resimden 1.
    • Remove AV port from camera.
Sonuç
Stephannie Allen
276 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G1
4 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 667
