Ana içeriğe geç
Sony Cyber-shot DSC-T9 CCD Module Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Battery: adım 1, 1 resimden 1.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 2, 1 resimden 1.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: adım 3, 3 resimden 1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: adım 3, 3 resimden 2. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: adım 3, 3 resimden 3.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 4, 1 resimden 1.
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 5, 1 resimden 1.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 6, 1 resimden 1.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 CCD Module Replacement, CCD Module: adım 7, 1 resimden 1.
    • This is the CCD module.
  8. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 8, 1 resimden 1.
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  9. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 9, 1 resimden 1.
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  10. Sony Cyber-shot DSC-T9 CCD Module Replacement: adım 10, 1 resimden 1.
    • The CCD module is now removed from the camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephannie Allen
276 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G1
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 987
