Ana içeriğe geç
Sony Cyber-shot DSC-T9 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-T9 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 LCD Replacement: adım 2, 1 resimden 1.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: adım 3, 3 resimden 1. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: adım 3, 3 resimden 2. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: adım 3, 3 resimden 3.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 LCD Replacement: adım 4, 1 resimden 1.
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 LCD Replacement: adım 5, 1 resimden 1.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 LCD Replacement: adım 6, 1 resimden 1.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 LCD Replacement, Back Cover: adım 7, 1 resimden 1.
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 LCD Replacement: adım 8, 1 resimden 1.
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 LCD Replacement: adım 9, 3 resimden 1. Sony Cyber-shot DSC-T9 LCD Replacement: adım 9, 3 resimden 2. Sony Cyber-shot DSC-T9 LCD Replacement: adım 9, 3 resimden 3.
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 LCD Replacement: adım 10, 3 resimden 1. Sony Cyber-shot DSC-T9 LCD Replacement: adım 10, 3 resimden 2. Sony Cyber-shot DSC-T9 LCD Replacement: adım 10, 3 resimden 3.
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 LCD Replacement: adım 11, 1 resimden 1.
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 LCD Replacement: adım 12, 1 resimden 1.
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 LCD Replacement, LCD: adım 13, 1 resimden 1.
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 LCD Replacement: adım 14, 1 resimden 1.
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 LCD Replacement: adım 15, 2 resimden 1. Sony Cyber-shot DSC-T9 LCD Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 LCD Replacement: adım 16, 2 resimden 1. Sony Cyber-shot DSC-T9 LCD Replacement: adım 16, 2 resimden 2.
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 LCD Replacement: adım 17, 1 resimden 1.
    • The LCD is now removed from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephannie Allen
255 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G1
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 47
Her zaman: 1,239
