Ana içeriğe geç
Sony Cyber-shot DSC-T9 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 2, 1 resimden 1.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 3.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 6, 1 resimden 1.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Motherboard Replacement, Back Cover: adım 7, 1 resimden 1.
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 3.
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 3.
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 12, 1 resimden 1.
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 Motherboard Replacement, LCD: adım 13, 1 resimden 1.
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 14, 1 resimden 1.
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 15, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 15, 2 resimden 2.
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 16, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 16, 2 resimden 2.
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 17, 1 resimden 1.
    • The LCD is now removed from the camera.
  18. Sony Cyber-shot DSC-T9 Motherboard Replacement, CCD Module: adım 18, 1 resimden 1.
    • This is the CCD module.
  19. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 19, 1 resimden 1.
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  20. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  21. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 21, 1 resimden 1.
    • The CCD module is now removed from the camera.
  22. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: adım 22, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: adım 22, 2 resimden 2.
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  23. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 23, 1 resimden 1.
    • Remove metal screw plate.
  24. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 24, 1 resimden 1.
    • Use pry stick to pop off ribbon.
  25. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove AV port from camera.
  26. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: adım 26, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: adım 26, 2 resimden 2.
    • The battery cover is located here.
    • Pull away from camera to remove.
  27. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 27, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 27, 2 resimden 2.
    • Grip on the top and bottom.
    • Pull up and out to remove motherboard and attached parts.
  28. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 3.
    • Flip motherboard parts to position shown.
    • There are three ribbons still attached to the motherboard.
    • Pull these three ribbons to remove remaining parts from motherboard.
  29. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 29, 1 resimden 1.
    • The motherboard is now removed from the camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephannie Allen
255 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G1
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
Superb,thank you very much !!!
Vedrasco Victor Vasili - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 642
