Ana içeriğe geç
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: adım 1, 3 resimden 1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: adım 1, 3 resimden 2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: adım 1, 3 resimden 3.
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 2, 1 resimden 1.
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 3, 1 resimden 1.
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    iSesamo Opening Tool
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 6, 3 resimden 3.
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 7, 1 resimden 1.
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: adım 8, 1 resimden 1.
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim
2.217 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 4,850
