Ana içeriğe geç
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: adım 7, 1 resimden 1.
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Megan East
555 İtibar
5 adet Kılavuz yazıldı
Ekip
Sam Houston State, Team 2-5, Blackburne Fall 2015 Sam Houston State, Team 2-5, Blackburne Fall 2015 üyesi
SHSU-BLACKBURNE-F15S2G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 2,367
