Ana içeriğe geç
Sony Cyber-shot DSC-TX7 Back Cover Replacement
Neye ihtiyacın var
    1. Sony Cyber-shot DSC-TX7 Back Cover Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement, Battery: adım 1, 2 resimden 2.
      • The battery compartment is located on the bottom of camera.
      • Move the slider from the 'lock' position to the 'open' position.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 2, 3 resimden 3.
      • Battery not shown.
      • Pull battery from compartment.
      • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
      • Shut compartment door.
      • Move the slider back to the 'lock' position.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Cyber-shot DSC-TX7 Back Cover Replacement, Front Cover: adım 3, 1 resimden 1.
      • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 4, 3 resimden 3.
      • The 4 mm length screws are located on each side and on the bottom of the camera.
      • 2 screws on each side (4 total).
      • 2 screws on bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 5, 1 resimden 1.
      • Gently pry around the front cover using the plastic opening tool.
      • Carefully separate front cover from body of camera.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 6, 1 resimden 1.
      • The front cover is now removed from the camera and the internal hardware is now visible.
      • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Cyber-shot DSC-TX7 Back Cover Replacement, Back Cover: adım 7, 1 resimden 1.
      • This is the camera with the front cover unscrewed and partially removed.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 8, 2 resimden 2.
      • Peel the black sticker from the motherboard.
      • Locate the connection ribbon between the front cover and the body of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 9, 2 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 9, 2 resimden 2.
      • Pull the ribbon out of the connection port so that they are completely disconnected.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 10, 2 resimden 2.
      • Use the plastic opening tool to separate the back cover from the inner hardware.
      • Continue until back cover can be pulled away from inner hardware.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 11, 2 resimden 1. Sony Cyber-shot DSC-TX7 Back Cover Replacement: adım 11, 2 resimden 2.
      • Remove the back cover so that the back cover is now completely separate from the body of the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Leslie Mundell
414 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G8
2 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,232
