Ana içeriğe geç
Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: adım 1, 2 resimden 2.
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 2, 3 resimden 3.
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Cover: adım 3, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 4, 3 resimden 3.
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 5, 1 resimden 1.
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 6, 1 resimden 1.
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
  7. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: adım 7, 2 resimden 1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: adım 7, 2 resimden 2.
    • Remove the three 4mm length screws located on the inside of the front cover with the Phillips #00 screwdriver.
  8. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: adım 8, 2 resimden 2.
    • Wiggle sliding lens cover after all screws are removed and separate from front cover.
Sonuç
Leslie Mundell
411 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G8
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 793
