Ana içeriğe geç
Sony Cyber-shot DSC-W150 Back Casing Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: adım 1, 1 resimden 1.
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 2, 1 resimden 1.
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 3, 1 resimden 1.
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 4, 1 resimden 1.
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 5, 1 resimden 1.
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 6, 1 resimden 1.
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: adım 7, 1 resimden 1.
    • The back cover should now be separated from the camera.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 5,152
