Ana içeriğe geç
Sony Cyber-shot DSC-W150 Front Casing Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W150 Front Casing Replacement, Back Casing: adım 1, 1 resimden 1.
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 2, 1 resimden 1.
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 3, 1 resimden 1.
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 4, 1 resimden 1.
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 5, 1 resimden 1.
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 6, 1 resimden 1.
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 7, 1 resimden 1.
    • The back cover should now be separated from the camera.
  8. Sony Cyber-shot DSC-W150 Front Casing Replacement, Front Casing: adım 8, 1 resimden 1.
    • Keep track of the small screws that you remove.
    • Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
  9. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 9, 1 resimden 1.
    • Remove the two screws at the top of the camera casing.
  10. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 10, 1 resimden 1.
    • After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
  11. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 11, 1 resimden 1.
    • After popping open the plastic piece, there is a screw that needs to be removed.
    • Remove the screw connecting the front casing to the electrical components.
  12. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 12, 1 resimden 1.
    • On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
    • Be cautious not to break the fragile pieces or scratch the LCD screen.
  13. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 13, 1 resimden 1.
    • Remove the two screws connecting the front casing to the electrical components using a screwdriver.
  14. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 14, 1 resimden 1.
    • Gently loosen the front casing by gently using your fingers to pull it apart.
    • Be cautious not to scratch any of the exposed electrical components.
  15. Sony Cyber-shot DSC-W150 Front Casing Replacement: adım 15, 1 resimden 1.
    • Fully remove the front casing from the camera and set it aside.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Julio Maravilla
191 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 33-73, Johann Spring 2010 Cal Poly, Team 33-73, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G73
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 6,167
