Ana içeriğe geç
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 2.
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 6, 2 resimden 2.
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 7, 3 resimden 1. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 7, 3 resimden 2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: adım 7, 3 resimden 3.
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Thomas
142 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G50
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 35
Her zaman: 11,610
