Giriş
Disassembling Sony Cybershot DSC-W5 in order to get to the battery terminal so that it can be replaced.
Parçalar
Hiçbir parça belirtilmedi.
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the two screws holding down the steel back plate.
Remove steel back plate.
Remove the orange cable connecting the battery terminal to the motherboard.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
