Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Sony Cyber-shot DSC-W55 Back Case Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 2, 2 resimden 2.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: adım 3, 2 resimden 2.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 4, 2 resimden 2.
    • Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 5, 1 resimden 1.
    • Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W55 Back Case Replacement: adım 6, 2 resimden 2.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
kkfong91
344 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G20
5 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Gracias a toda la gente de Ifixit, muy util esta aplicacion y muy buena gente!!.
Ruben - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,703
