Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Sony Cyber-shot DSC-W55 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: adım 3, 2 resimden 2.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Front Case: adım 7, 1 resimden 1.
    • Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
  8. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: adım 9, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: adım 9, 2 resimden 2.
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Motherboard - First Half: adım 11, 1 resimden 1.
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 12, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 13, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 13, 2 resimden 2.
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 2. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 3.
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 15, 3 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 15, 3 resimden 2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 15, 3 resimden 3.
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 16, 2 resimden 1. Sony Cyber-shot DSC-W55 LCD Screen Replacement: adım 16, 2 resimden 2.
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eddie Lo
319 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G20
5 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 13,869
