Ana içeriğe geç
Sony Cyber-shot DSC-W55 Lens Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Lens Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement: adım 2, 2 resimden 2.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: adım 3, 2 resimden 2.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Lens Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement: adım 4, 2 resimden 2.
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Lens Replacement: adım 5, 1 resimden 1.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Lens Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement: adım 6, 2 resimden 2.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
    Muchas gracias, muy claro!!
    Ruben - Yanıt
  7. Sony Cyber-shot DSC-W55 Lens Replacement, Front Case: adım 7, 1 resimden 1.
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Lens Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-W55 Lens Replacement: adım 8, 3 resimden 3.
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: adım 9, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Lens Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-W55 Lens Replacement: adım 10, 2 resimden 2.
    • Gently pull the lens container out of the camera.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
kkfong91
344 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G20
5 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - Yanıt
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 28
Son 30 gün: 127
Her zaman: 22,135
