Ana içeriğe geç
Sony Cyber-shot DSC-W570 Case Cover Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: adım 1, 1 resimden 1.
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 2, 1 resimden 1.
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 3, 1 resimden 1.
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 4, 2 resimden 2.
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 5, 2 resimden 2.
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zizheng Su
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 812
