Giriş
Be sure to remove the battery before beginning this procedure, and use caution when handling the flash capacitor. Do not touch the capacitor leads, or you may receive a nasty shock.
Neye ihtiyacın var
Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
These are the two cables connecting the LCD screen to the motherboard below the screen.
These are buttons for menu. Be sure to check that the flash settings are correct for your scene. Do not replace flash until settings are verified.
2 farklı kişi bu kılavuzu tamamladı.
