Giriş
The motherboard is one of the hardest components on the camera to replace. Be very careful when taking apart the ribbons, you could accidentally damage other parts of the camera.
Neye ihtiyacın var
Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
Bu adımda kullanılan alet:Tweezers$4.99
Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
After the screen is off, work the spudger under three clips to remove the metal plate.
Bir başkası bu kılavuzu tamamladı.
