Ana içeriğe geç
Sony Cyber-shot DSC-W800 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: adım 1, 3 resimden 1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: adım 1, 3 resimden 2. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: adım 1, 3 resimden 3.
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W800 LCD Screen Replacement: adım 6, 2 resimden 2.
    Satın Al
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Thomas Campo
809 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 2,580
