Ana içeriğe geç
Sony Cyber-shot DSC-W800 Lens Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: adım 1, 3 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: adım 1, 3 resimden 2. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: adım 1, 3 resimden 3.
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement: adım 2, 2 resimden 2.
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-W800 Lens Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: adım 5, 1 resimden 1.
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement: adım 6, 2 resimden 2.
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: adım 7, 2 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: adım 7, 2 resimden 2.
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-W800 Lens Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-W800 Lens Replacement: adım 8, 3 resimden 3.
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Thomas Campo
827 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G5
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 72
Her zaman: 4,955
