Ana içeriğe geç
Sony Cyber-shot DSC-WX220 Lens Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 2, 2 resimden 2.
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: adım 3, 3 resimden 3.
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 4, 2 resimden 2.
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Lens Assembly: adım 5, 1 resimden 1.
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 6, 1 resimden 1.
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 8, 2 resimden 2.
    • Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
    • Pull the ZIF cable out.
  9. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: adım 9, 1 resimden 1.
    • Lift the lens out of the case.
    • Pull out the ZIF cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kate Glazer
621 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S6G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 49
Her zaman: 1,201
