Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide shows how to replace the outer case if damaged.
  1. Slide the gray switch from lock to open position.
    • Slide the gray switch from lock to open position.
  2. Pull down on the blue tab to release the battery. Pull down on the blue tab to release the battery.
    • Pull down on the blue tab to release the battery.
  3. Use a PH00 screwdriver to remove the  five 3.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws.
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Pry apart the case gently using a plastic opening tool. Pry apart the case gently using a plastic opening tool.
    • Pry apart the case gently using a plastic opening tool.
Sonuç
Kate Glazer
609 İtibar
5 adet Kılavuz yazıldı
Takım
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S6G3
3 Üyeler
Bir Yorum
Where i can buy that outer body ?
chandraprakash tiwari - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 347
