Ana içeriğe geç
Sony Cyber-shot DSC-WX220 Outer Case Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-WX220 Outer Case Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Outer Case Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-WX220 Outer Case Replacement: adım 2, 2 resimden 2.
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Outer Case Replacement, Outer Case: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX220 Outer Case Replacement, Outer Case: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX220 Outer Case Replacement, Outer Case: adım 3, 3 resimden 3.
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Outer Case Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX220 Outer Case Replacement: adım 4, 2 resimden 2.
    • Pry apart the case gently using a plastic opening tool.
Sonuç
Kate Glazer
621 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S6G3
3 Üyeler
Bir Yorum
Where i can buy that outer body ?
chandraprakash tiwari - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 669
