Ana içeriğe geç
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 3.
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 4, 1 resimden 1.
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 5, 1 resimden 1.
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 6, 2 resimden 2.
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 7, 3 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 7, 3 resimden 2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 7, 3 resimden 3.
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 8, 2 resimden 2.
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 9, 3 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 9, 3 resimden 2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 9, 3 resimden 3.
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: adım 10, 2 resimden 2.
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Matt Garthwaite
125 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017 üyesi
IUPUI-WILSON-SU17S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 1,824
