Ana içeriğe geç
Sony Cyber-shot DSC-WX350 Lens Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 2. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 3.
    • Use the J00 screwdriver to take out the four 3mm black screws on the bottom and both sides of the camera.
  2. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 2, 1 resimden 1.
    • On the bottom of the camera slide the button over to open the battery case. Inside the battery opening use the J00 screwdriver to take out the single 3mm black screw.
  3. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 3, 1 resimden 1.
    • Use the J00 screwdriver to take out the single 3mm black screw on the left side of the camera .
  4. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry open the back cover off.
  5. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 5, 1 resimden 1.
    • Use your fingers to slide out the controller wheel board 's lower end, then unhook the other end.
  6. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 6, 1 resimden 1.
    • Take the LCD off by undoing the zif and sliding it out.
    Don’t REMOVE the zif connector like on the picture!
    To open the zif connector:
    - this is the black (or the brun part on the other connector) part that pivots, the white part don’t move
    - I prefer to use my thumb(s) and my fingernail(s) to control the force
    - put your thumb on the side of the camera, just in front of the white part, to avoid the camera to slide toward yourself
    - slide you fingernail below the black part
    - if you have small finger, you can use both hand to reduce the effort on the zif
    - lift up the black part, that will pivot and terminate at 90° angle with the white part
    Alain Spineux - Yanıt
  7. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 7, 2 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 7, 2 resimden 2.
    • Once the LCD is off use the J00 screwdriver to take out the two 3mm silver screws. Once the screws are taken out pull off the piece with your fingers.
  8. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 8, 3 resimden 3.
    • Now take out the 3 zifs by first opening the zif latch with your fingers and then sliding it out.
  9. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 9, 1 resimden 1.
    • Carefully remove the lens assembly from the camera.
  10. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 10, 2 resimden 2.
    • In order to access the CCD, loosen the 3 screws holding its metal lid.
    • In order to access the lens mechanics, take out the 4 3mm screws on the edge of the lid, then the single 3 mm screw next to the motor.
  11. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 11, 1 resimden 1.
    • Carefully tear off the ribbon glued to the plastic.
  12. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 12, 2 resimden 1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: adım 12, 2 resimden 2.
    • Pull out the cogwheel with the drive unit.
    • Now you can access the lens inner mechanics. You might wanna cover the CCD and the inner lens opening with tape to prevent dust from entering before you try to clean anything.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joshua R Hammel
276 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017 üyesi
IUPUI-WILSON-SU17S1G1
4 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Hi, I think on my sensor chip is some dust. Is it possible to clean that or is it one unit with lens? There is no picture about this detail….
Arno - Yanıt
Hi there, does anyone know who I could go to to fix the lens (replace them) on my Sony wx-350 camera Thank you!
Joshua O'Brien - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 5,173
