Ana içeriğe geç
Sony Cyber-shot DSC-WX80 LCD Screen Replacement
  1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
    • Your LCD screen is now removed and you can replace it!
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2 Comments
Would the wheel be included with the LCD? The wheel on my camera is broken, and I would like to fix/replace it, so should I just order a new LCD screen?
Caleb V. - Yanıt
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
Jose Luis Martínez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,626
