Ana içeriğe geç
Sony Cybershot DSC-HX100V Control Button Sensory Panel Replacement
Neye ihtiyacın var
  1. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement, Control Button Sensory Panel: adım 1, 1 resimden 1.
    • Make sure the camera is turned off.
    • Press the ON/OFF button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 2, 3 resimden 1. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 2, 3 resimden 2. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 2, 3 resimden 3.
    • Use the Phillips screwdriver size #00 to remove the 1.9mm #00 screws.
    • Remove 2 screws on the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 3, 1 resimden 1.
    • Tilt the screen forward.
    • Remove the two 1.9mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 4, 1 resimden 1.
    • Pull the back part of the camera upward.
    • Use the spudger to help pry open the back panel.
  5. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 5, 1 resimden 1.
    • Open the back panel to view the inside of the camera.
    • Gently pull the orange ribbon cable to separate the two parts of the camera.
    • Set the back part of the camera aside.
  6. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 6, 2 resimden 1. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 6, 2 resimden 2.
    • Turn the front part of the camera clockwise, so the lens is facing the right.
    • Gently remove the silver piece from the side of the camera. It should come out easily using your fingers.
  7. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 7, 1 resimden 1.
    • Remove two 3.38mm #00 screws from the sensory panel with a Phillips screwdriver size #00.
    • The first screw is located on the left side of the panel and the second screw is located near the top of the panel.
  8. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: adım 8, 1 resimden 1.
    • Gently lift the orange ribbon cable with your finger to disconnect it.
    • Remove the sensory panel and replace it.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sydney Counts
307 İtibar
1 Kılavuz yazıldı
Ekip
5 Yorum
Where can you purchase this panel/
board?
Dana - Yanıt
yes please. i need to fix my camera. thanks.
ploter64 - Yanıt
I have issues when I turn the wheel to change the settings on manual mode. Would this be the same part?
Also, where can I find it? I tried to have it professionally repair and was told it needed the whole board and that it was not available any more. Thanks!
Ariel Donayo - Yanıt
The exact same thing has happened with mine. This happened before but the camera was in warranty so Sony repaired it. It is longer in warranty now but has happened again.
Sam - Yanıt
Sam, where did you find parts?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 1,868
