Ana içeriğe geç
Sony Cybershot DSC-W80 Lens Replacement
Neye ihtiyacın var
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: adım 1, 2 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Battery: adım 1, 2 resimden 2.
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: adım 2, 1 resimden 1.
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 2. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 3.
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: adım 4, 1 resimden 1.
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: adım 5, 2 resimden 1. Sony Cybershot DSC-W80 Lens Replacement: adım 5, 2 resimden 2.
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 2. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 3.
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 54
Her zaman: 909
