Ana içeriğe geç
Sony DCR-DVD 108 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
Sonuç
Elijah DeWolf
589 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 894
