Ana içeriğe geç
Sony DCR-DVD 108 Motherboard Replacement
Neye ihtiyacın var
  1. Sony DCR-DVD 108 Motherboard Replacement, Sony DCR-DVD 108 Case Disassembly: adım 1, 1 resimden 1.
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Motherboard Replacement: adım 4, 1 resimden 1.
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Motherboard Replacement: adım 5, 2 resimden 1. Sony DCR-DVD 108 Motherboard Replacement: adım 5, 2 resimden 2.
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
    • Be careful not to bend the ribbon cables.
    • There is a hidden wire on the bottom of the board that should also be removed.
  7. Sony DCR-DVD 108 Motherboard Replacement: adım 7, 3 resimden 1. Sony DCR-DVD 108 Motherboard Replacement: adım 7, 3 resimden 2. Sony DCR-DVD 108 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
  8. Sony DCR-DVD 108 Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard up from the outside edges to remove.
Sonuç
In order to reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Elijah DeWolf
577 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 590
