Ana içeriğe geç
Sony DSC-RX100MA Back Cover Replacement
Neye ihtiyacın var
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 3.
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 3.
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 6, 2 resimden 2.
    • Remove the back cover
Sonuç
Bir başkası bu kılavuzu tamamladı.
KC Egger
294 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 3,416
