Ana içeriğe geç
Sony DSC-RX100MA Back Cover Replacement
Neye ihtiyacın var
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove battery by sliding the tab to open the cover
    FixBot'a Sor
    Yorum Ekle
  2. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
    FixBot'a Sor
    Yorum Ekle
  3. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 3, 3 resimden 3.
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
    FixBot'a Sor
    Yorum Ekle
  4. Sony DSC-RX100MA Back Cover Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  5. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA Back Cover Replacement: adım 5, 3 resimden 3.
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
    FixBot'a Sor
    Yorum Ekle
  6. Sony DSC-RX100MA Back Cover Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA Back Cover Replacement: adım 6, 2 resimden 2.
    • Remove the back cover
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
KC Egger
315 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Hi! Two of the 1mm screws fell out of my camera from behind the display, where can I find new ones? I keep checking amazon and its kits of 750pcs+ and they don't seem like the right 1mm screws. Do you know where I can get some?
Victoria Gallardo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 67
Her zaman: 4,187
