Ana içeriğe geç
Sony DSC-RX100MA Image Sensor Replacement
Neye ihtiyacın var
    1. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: adım 1, 3 resimden 3.
      • Remove battery by sliding the tab to open the cover
      FixBot'a Sor
      Yorum Ekle
    2. Sony DSC-RX100MA Image Sensor Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 2, 3 resimden 3.
      • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
      • All screws in the camera can be removed with the PH 0 driver head.
      FixBot'a Sor
      Yorum Ekle
    3. Sony DSC-RX100MA Image Sensor Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 3, 3 resimden 3.
      • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
      • Remove the marked 2.5 mm screws with the screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. Sony DSC-RX100MA Image Sensor Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 4, 2 resimden 2.
      • Using the plastic opening tools, carefully pry off the bottom plate.
      • Do not pull too hard as you may break the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    5. Sony DSC-RX100MA Image Sensor Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 5, 3 resimden 3.
      • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
      • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
      FixBot'a Sor
      Yorum Ekle
    6. Sony DSC-RX100MA Image Sensor Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 6, 2 resimden 2.
      • Remove the back cover
      FixBot'a Sor
      Yorum Ekle
    1. Sony DSC-RX100MA Image Sensor Replacement, Screen: adım 7, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement, Screen: adım 7, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement, Screen: adım 7, 3 resimden 3.
      • Move side panel to get access to screws
      • Remove two screws (black 2.5mm) with PH #0 screwdriver
      FixBot'a Sor
      Yorum Ekle
    2. Sony DSC-RX100MA Image Sensor Replacement: adım 8, 2 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 8, 2 resimden 2.
      • Remove back panel assembly while still keeping ribbon cable attached
      • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
      FixBot'a Sor
      Yorum Ekle
    3. Sony DSC-RX100MA Image Sensor Replacement: adım 9, 2 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 9, 2 resimden 2.
      • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
      FixBot'a Sor
      Yorum Ekle
    1. Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: adım 10, 2 resimden 1. Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: adım 10, 2 resimden 2.
      • Using the Philips Screwdriver, remove the screw (black 3mm) located on the copper casing.
      FixBot'a Sor
      Yorum Ekle
    2. Sony DSC-RX100MA Image Sensor Replacement: adım 11, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 11, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 11, 3 resimden 3.
      • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
      • Remove casing.
      FixBot'a Sor
      Yorum Ekle
    3. Sony DSC-RX100MA Image Sensor Replacement: adım 12, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 12, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 12, 3 resimden 3.
      • Using the Philips screwdriver, remove the three (silver 3mm) screws
      • Remove the screw (silver 2mm) from the upper right hand corner
      FixBot'a Sor
      Yorum Ekle
    4. Sony DSC-RX100MA Image Sensor Replacement: adım 13, 3 resimden 1. Sony DSC-RX100MA Image Sensor Replacement: adım 13, 3 resimden 2. Sony DSC-RX100MA Image Sensor Replacement: adım 13, 3 resimden 3.
      • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
      • Give it a little wiggle and you should feel the SD card holder come out.
      FixBot'a Sor
      Yorum Ekle
    5. Sony DSC-RX100MA Image Sensor Replacement: adım 14, 1 resimden 1.
      • Now you can remove the marked gold ribbon cable from the SD card holder.
      • Utilize extreme caution while removing because the ribbon cables are extremely fragile and important to the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Isaiah De Leon
442 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 4,170
